0
Score
Avatar
Pablo
Asked
Screen problems awaking from sleep
History
Hello,
I just replaced the LCD screen following your guide. The screen and isight camera worked fine. I also connected the computer to an external display and worked fine. The problem happens when I put the computer to sleep using any method (apple menu, power button, closing the lid). The computer wakes up but the screen is white wth some flickering and lines. In this state I can connect it to an external display, press function F7 and see the desktop in that monitor. So the computer is running but the screen is white!!! The only way to recover from this problem is by rebooting
Any ideas on how to fix this?
Thank you in advance
Pablo
Post Answer
0
Score
Avatar
rab777hp
12.6k
Answered
PermalinkHistory
Check to make sure none of the connections are loose.
I just just finished redoing the process again, checked the connections and everything seems tightly connected. Any particular connector/cable that I should triple check? Thank you, Pablo
Pablo,
Display data cable and inverter cable would be your best bet.
rab777hp,
Add Your Answer
