0
Score
Avatar
nsolis
Asked
Home Button will not work after replacing digitizer and screen
History
Ok, I know I must have done something horrible to the connection of the Home Button when I replace the broken digitizer and screen. But for the life of me I don't know which part to replace to make the home button work again. I must have damage it when I peel off the front screen with a spudger and a hair dryer. Somehow I must have damage the cables. So my question is: Which component do i replace? And where can I purchase that component? By the way the screen and digitizer works perfectly now. But the Home Button who was working perfectly prior to the repair is no longer functioning.
Please help. thanks in advance.
Post Answer
0
Score
Avatar
oldturkey03
59.5k
Answered
PermalinkHistory
Okay, here is the official Apple help :) "The Home button is not working
1. Put the iPhone to sleep.
2. Wait a couple of seconds.
3. Press the Home button.
4. iPhone should wake up.
5. If iPhone does not wake up, then iPhone should be serviced. " The best way to tell if it's hardware or software is to do a complete restore and set up as a new phone ( not restore from backup ). If the issue resolves, it's software ... if not it's hardware. The home button has a little ribbon connector that is a bit too prone to get rusty and when this happens the electrical current sometimes doesn't flow as it should. So make sure that all your cables are connected properly, that the ends are free of corrosion and if nothing helps, you can always try to replace the button and the cable. http://shop.ebay.com/i.html?_nkw=iphone+... ....good luck
0
Score
Avatar
Jeff Chen
Answered
PermalinkHistory
Try this solution first! Only takes a few seconds. it worked for me!!!
http://www.ifixit.com/Answers/View/56206...
-Jeff
0
Score
Avatar
Ryan
529
Answered
PermalinkHistory
Sometimes when i replace a digitizer, i will accidentally bent one of the home button contacts out of place... check the "metal prongs" coming out of the backside of the lcd/digitizer assembly, they should be straight and be sticking out enough so that they can touch the metal pads on the dock flex cable. Also i like to scrape the metal pads on the dock flex cable a little bit to get a better connection.
- you can test wether the problem is the dock cable or the home button by bridging the home button pads with a paper clip, while the screen lcd is plugged in you should see the iPhone act as if the home button was pressed if the dock connector/logic board is working fine. home button contact pads should be to the Right of the text "J3".
Edited by
Add Your Answer
