0
Score
Avatar
pam
Asked
My Dell Inspiron 1526 has a mini card for wireless internet connection
History
The icon in the lower right corner shows that I have successfully gotten on the internet - BUT in fact I have NOT! I ran the diagnostic test for the wireless WLAN card and I get an error message that states "Internet IP Ping" FAILED. I have not idea what this means. Can I correct this problem with settings/ or software? Or do I need to replace the card? It was working fine, but recently has shut done (only this card) with a few error messages. Was that an indication that the card had a problem and was going bad?
Thanks in advance - your answers are always so very helpful!
Edited by
This question was migrated from http://meta.ifixit.com/.
iRobot,
Post Answer
3
Score
Avatar
oldturkey03
59.5k
Answered
PermalinkHistory
Just in case this should still be an issue :) pam, Ping is a computer network administration utility used to test the reachability of a host on an Internet Protocol (IP) network and to measure the round-trip time for messages sent from the originating host to a destination computer. The name comes from active sonar terminology.
Ping operates by sending Internet Control Message Protocol (ICMP) echo request packets to the target host and waiting for an ICMP response. In the process it measures the time from transmission to reception (round-trip time)[1] and records any packet loss. The results of the test are printed in form of a statistical summary of the response packets received, including the minimum, maximum, and the mean round-trip times, and sometimes the standard deviation of the mean.
So simplified it is that your computer makes a call to another number (IP) and measure how long it took to connect and to return with the data. If you can not connect to the other computer (IP adress) you get a fail.
First off. Restart your computer. Restart your router or your modem since I am not sure how you connect. Make sure that all Cables are connect properly.
It is most likely a software issue related to your hardware. What I would do just to test this is to uninstall my wireless network.
Click Start, and then click Control Panel.
Click system
Click hardware
click device manager
you should now see the devices on your computer. Make sure that none of your devices has a question mark on it.
go to the Network adapter and find your wireless adapter.
Uninstall the device. (Right the proper name down just in case you need to get a driver for it)
After that I would reboot the computer. This time around Windows should find your network adapter and reinstall it. If it does not find it, you may have some hardware problems with the network adapter.
That is for the hardware part. For the setup of a wireless network here are a few links that will help http://www.online-tech-tips.com/computer... and http://www.microsoft.com/windowsxp/using...
Please let us know how you are progressing. I know that this can get extremely frustrating. So do one thing at a time, if you do to much at once you will lose sight over what needs to be done. this can be tedious and a royal PITA to get straight but patience will prevail....good luck and let us know.
Edited by
Agreed, networking can be such a PITA. Great answer!
Gabe,
+ nice research
mayer,
0
Score
Avatar
bunnie81
Answered
PermalinkHistory
I'd never bothered using my wireless card until a few months ago, and I was having the exact same problems (the protocol stuff). I guess I took an easy way out and just bought a little "Encore" antenna wireless USB device, and now I can connect to the Internet with my Dell Inspiron 1526 laptop.
Add Your Reply
