0
Score
Avatar
tmjoes
Asked
Why is there a symbole of a folder
History
After monting new batteri, there is a symbole of a folder with a sign of danger?
Post Answer
0
Score
Avatar
jcarm75
147
Answered
PermalinkHistory
There is a problem with the iPod operating system. Connect it to your computer to reset it from there. If you cannot, you need to run the iPod in diagnostic mode.
Enable Diagnotic Mode in 3rd Generation iPod
Source: http://www.activewin.com/tips/tips/apple...
iPod 3rd Generation - Tips Section
How To Enable Diagnosis Mode
Posted By: Byron Hinson
Last Updated: September 4th 2003
Tip Difficulty Level: Novice
How This Tip Works
Recording tests have been removed in firmaware 2.0.1, changes noted in red. The tests below are as they appear on iPods with dock connectors running iPod software 2.0:
  • A.5 IN 1
  • B.RESET
  • C.KEY
  • D.AUDIO
  • E.REMOTE
  • F.LIN REC (FW ID)
  • G.SLEEP
  • H.A2D
  • I.OTPO CNT
  • J.RECORD (LCM)
  • K.CHG STUS
  • L.USB DISK
  • M.CHK SUM
  • N.DISPLAY (CONTRAST)
  • O.HDD SCAN
  • P.RUN IN
To enter Diagnostic Mode: Reset, at Apple logo press and hold "Previous", "Next", and "Action"
The Tests:
A. 5 IN 1 - Runs J through N
B. RESET - Reset
C. KEY - Allows 5 seconds to press all buttons, if any don't respond or time expires it fails
D. AUDIO - Checks audio subsystem; a Pass returns "0X00000000 DONE" and if you have your earbuds in you'll get a beat.
E. REMOTE - When it fails to find the remote control it returns "RMT FAIL"
F. FIREWARE - Apparently checks FireWire bus; a Pass returns "FW PASS"
G. SLEEP - goes to sleep; requires reset to wake (unless we didn't wait long enough)
H. A 2 D - Checks power subsystem; test unit returned "3.7V 0X000000E2 CHG OK FW 1 BAT 1"
I. OTPO CNT - Scroll wheel response represented as hexadecimal
J. LCM - Tests display, requires pressing "Action" to advance through 3 patterns
K. RTC - Real Time Clock
L. SDRAM - Memory; test unit returns "PASS"
M. FLASH - pretty sure it's the rom version; test unit returns "0X00005281" Note: this will be different depending on the build of the firmware installed
O. HDD SCAN - Hard drive; will take several minutes
P. RUN IN - Runs continuous tests of chipsets (we think); LCM, RTC, SDRAM, OPTI, HDD (controller), TI1394
Add Your Answer
