How to fix the power, the mute and the volume button right?
I've bought a new housing for my Iphone 3GS, but when i want to fix the power button it doesn't come out.
And the mute and the volume buttons aren't properly secured, they are a bit crooked, the mute button is also a bit shaky.
So I'm helpless :(
I'm grateful for evry post and I will add somm images later that you can see it better!
greez
erto722
edit: here the images, the quality is not so good but you can guess which part which is!
you can see that the volume buttons arn' t straight line
pleas check it if there is someting wrong installed!
edit pictuer of the black screen:
20 Comments
thanks for the answers, you' ve got 2 scores from me :)
"electrical tape" or "blutak"
is that ok because I think the current should be lead or not?
by erto722
not sure what current should be lead or not means? but thanks for the votes.. have you fixed the problem?
by pollytintop
I mean "conduct electricity" (google translator -.-)
I fixed the problem not yet in cours of my question.
(I hope this is better understandable)
by erto722
Blu tak is a reusable gummy type stuff used for sticking posters to walls etc without ruining paint/ wallpaper. In this instance you use it to stick the mute button fro the outside of iPhone. Leaving you both hands fre to put vibrate flex in place. Then you cam remove Blu tak. I don't know if you have something like this where you live. There should be no problem with conductivity since it is not left in iphone
by pollytintop
is the blu tak also ok for the power button because its too much inside the housinge
by erto722
Show 15 more comments
