0
Score
Avatar
George Rotter
Asked
Adjust A Franz Metronome?
History
I have a Franz LM-4 electric Metronome. I don't think the company repairs them anymore. Yes, there was something wrong, since my wife couldn't adjust the beats per second. I opened it up and found that the center screw needed to be tightened to the adjustment shaft - BUT at what position of the shaft?
While I had it open, the copper strip with an ~90 degree bend in it got loose and fell out. Don't know what it does or where it should be inside.
There are 2 metal screws that are probably supposed to be used for speed adjustment, but there must be some procedure to follow & I don't know what it is. Any help out there? Any former Franz technicians able to help?
Thanks, George
Edited by
This question was migrated from http://meta.ifixit.com/.
iRobot,
Post Answer
Score
Avatar
Jordan
13
Answered
PermalinkHistory
I just fixed mine! All you need to adjust is the three screws holding the needle beam in place. The angle of that wire is determined by the position of the needle when you are tightening everything up -- if you tighten everything up and the needle isn't at dead center, then 60 bpm will be WAY too slow. Use 60 because you can set it with a watch. I can't say i have it to a science, but I can say that it's all in where the needle is set when you tighten everything up.
0
Score
Avatar
Christopher Mayer
Answered
PermalinkHistory
The copper strip just stops the wheel from spinning. I'm not sure if it's even a necessary part. My metronome is broken too and i'm currently trying to fix it.
Add Your Answer
