0
Score
Avatar
Sunshine
73
Asked
What is the plastic surround?
History
I am trying to do the battery replacement. In the process the front glass cracked. I got it off, but am thinking now I have to replace it.
I read this in the guide:
. If the plastic surround is not flush with the front face of the glass panel, gently peel it off and stick it down.
What is the plastic surround? Is it on the front panel or in the back? IS it the thin rubber like thingie between the case of the front panel and the shiny back case? I don't know what to peel off and stick down if I don't know what it is!
Edited by: Sunshine ( )
What guide are you following and what step of the guide is that from?
Matt Barnes,
Front panel, step 8, third bullet point.
Sunshine,
Post Answer
0
Score
Avatar
Marc
783
Answered
PermalinkHistory
The correct term for this part is mid frame bezel gasket. The digitizer glass is adhered to this with double sided adhesive and it is the part that actually snaps back into the frame. More likely than not you will need to replace it each time when removing the digitizer glass. You can buy the entire assembly pre assembled here:
iPod Touch Gen 3 Front Panel Assembly
Good luck and please get back to us with how you did.
Product Image
Touch portion of the iPod. Includes frame and home button. — 19 available at 69.95 each.
Add Your Answer
