0
Score
Avatar
Chad
175
Asked
White screen after repair
History
I had someone bring me an iPhone 3GS they had attempted to take apart (to replace the glass) by prying apart the chrome bezel from the back case. Needless to say, they broke several components in the process. I had to replace the dock connector assembly, the power/headjack/mute-toggle/etc. ribbon cable and vibrate motor. I also replaced the glass digitizer and LCD.
When I power it on, I never get the apple logo, and it goes right to a white screen. If I hit the power/lock button it will go black screen. Hit it again and white screen. The mute toggle works (phone will vibrate), and iTunes recognizes the iPhone just fine. Holding home button will bring up voice control. I have tried swiping the digitizer screen to see if I can get some sort of audible response, but no luck. I have tried multiple new LCD and digitizer's, and same symptoms.
I have even restored the firmware 3 times, no luck. Can anyone help?
Edited by: oldturkey03, rj713, and mayer ( ) , David Hodson ( ) , Chad ( )
What was the problem now? Did you solve it?
hans,
i have the exact same problem :(
bob,
i got the same problem is . after i reset my iphone 3gs and turn the power on it's come to logo apple like it was but when i hold the power button to sleep mode then it's come to white screen and i trying to reboot again it's come to menu then i just click on the power and turn it back to white screen. Anyone know how to fix it . Please help me out thank you and this phone i never fix it or give someone to fix it yet . Please if you have any command how to fix it . thank you .. vin
vin ,
Post Answer
4
Score
Avatar
pollytintop
39k
Answered
Accepted Answer
PermalinkHistory
when someone has taken no care or paid any attention to the help guides that are free all over the www it's a wonder anything works at all. well done to you for getting it to this stage. I'd imagine that in prising apart the display they have either levered on a component or they have damaged the LCD connector/path in someway. you need to examine the connections and then follow the path looking for fractures in the gold wiring of the motherboard (which you can then solder/jump) or use a infrared thermometer to isolate the non working component. my guess is connector 1 is slightly off the board or pin bent so that only some of the pins are in contact with the motherboard.
Thanks, I will look into the areas you suggested and let you know how I get along.
Chad,
"when someone has taken no care or paid any attention to the help guides that are free all over the www it's a wonder anything works at all"... I hate comments like this. First, at least they tried to fix it themselves instead. Secondly, do you fix everything the first time you try it? For me, the first couple of times doing anything is the learning process.
Jimmy Cochran,
@Jimmy Cochran, I changed your answer to a comment, since it obviously was not an answer. BTW, I think what was implied here was, that somebody tried to fix it (nothing wrong with that) but then expect someone else to fix it (after it was further broken)
oldturkey03,
@ oldturkey03 I can't believe you felt compelled to reply to that.
Jimmy Cochran,
@Jimmy Cochran, hate is such a strong word....:-)
oldturkey03,
Show 1 more comment
0
Score
Avatar
Randy
Answered
PermalinkHistory
Here is a video showing almost step by step how to fix the WSOD on the iPhone 3GS - https://www.youtube.com/watch?v=WJksdOgd...
0
Score
Avatar
e2g1216
Answered
PermalinkHistory
Just press at the same time power and home botton for ten seconds and wait to see Aple logo.
BUUM!!! it's done.
Edited by: e2g1216 ( )
Add Your Answer
