0
Score
Avatar
Christer Nygard
Asked
Change Logic Board from 2.66 to 2.53 GHz
History
I just wonder if i can change my broken logic board to a cheaper logic board like 2.53 GHz
My macbook pro unibody 15" is a mid 2009 computer with originally a 2.66 GHz Logic board with in.
Does a 2.53 logic board from mid 2009 fit. or do i have any other options? it's the A1286 model.
Post Answer
Score
Avatar
Skippy722
1.8k
Answered
PermalinkHistory
You have to use the 2.66GHz logic board, the 2.53 has a different shape. Take a look at the differences between the two.
2.53GHz logic board - MacBook Pro 15" Unibody (Mid 2009) 2.53 GHz Logic Board
2.66GHz logic board - MacBook Pro 15" Unibody (Mid 2009) 2.66 GHz Logic Board
Product Image
2.66 Motherboard / Ports: Mini DisplayPort, 1000BaseT Ethernet, Firewire 800, 2 USB 2.0, SD card slot,... — Currently out of stock.
Product Image
2.53 GHz Motherboard / Ports: FireWire 800, Mini DisplayPort, 1000BaseT Ethernet, 2 USB 2.0, SD card slot,... — 5 available at 849.95 each.
0
Score
Avatar
weidyc
55
Answered
PermalinkHistory
It will but you'll need the center bracket mount piece (the one in the 2.66 and up are different, about $20 more less) that the fan and the logic board mounts to in the case, also you have to get the correct heat sink (meaning you can't use the one from the 2.66), better get a logicboard with the heat sink still attached and un disturbed, that way you don't have to clean and reapply the thermo coumpound. you will need one extra logic board screw, because the 2.53 one uses one more screw to mount then the 2.66 and up do. and the logicbaord would need the mid 2009 2.53 (single fan) size fan (the fan is bigger then the 2.66), But it all works if you want to swap. I did it, upgrade and downgrade. i upgraded a 2.53 to a 3.06, and i replaced a 2.8 with a 2.53 So I know all about it. Personally i would upgrade not downgrade. the 2.53 logic board, i find are a little buggy. Why not try for a used 3.06 gHZ logic board, then all you need is just the logic board (preferably with the heat sink attach, otherwise you need thermo compound). They dont cost a whole lot used, i say a ball park range around $400-$700 used on ebay when you find one.
0
Score
Avatar
Jason Wilson
Answered
PermalinkHistory
Also you would need to change the keyboard and trackpad as the 2.53ghz models are not compatible with the 2.66Ghz + models.
0
Score
Avatar
weidyc
55
Answered
PermalinkHistory
That is incorrect, the keyboards track pads are compatible. I have done this many times
Add Your Answer
