Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
300 Questions View all
Power up without internal keyboard
Hi,
I recently spilled liquid on my MacBook Pro 15" Unibody Mid 2009. It will only turn on if I disconnect the keyboard ZIF connector. Too bad the power button is part of the broken keyboard. Is there any way to "jump start" that model?
For older and newer MBPs I have found information regarding how to do that (always shorting to pads on the logic board). Where are those pads on the logic board of my model?
Best Benjamin
Score -1
Add a comment
1 Answer
Chosen Solution
See this
Answer for a 17" machine. Your solution will be similar look for the description power button - you may need a magnifying glass.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N.
2 Comments:
Thanks. For the pre-unibody MBPs this task was quite easy. But the newer models have no markings on the PCB.
by
Add a comment
Add your answer
Benjamin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 5,962
