Why can't I hear anything from the right side?
I can't hear anything from my right headphone, and I opened it up and it looks like there isn't a problem, but I'd rather get a second opinion.
@evolangel use a multimeter and check for continuity from the connector to each one of the drivers (speaker). It is possible that the wires at either the connector or the drivers got disconnected. If you have a proper connection then you want to check the driver separately. connect some temporary wires from the working side to the not working one. The driver should then work. If it does not, you will have to replace it.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 157
