0
Score
Avatar
jaime ruiz
Asked
keyboard and trackpad not working
History
This was my first macbook air. I like it a lot, but I rarely use it. Well, I have a lot of computers at my house.
Since last year that I purchased the newer macbook air with the ssd, this was not doing anything much.Now this year with the ipad, even less.
However something strange happened to this macbook air when I took it out and try to sell it on ebay.
Let me explain. When I power on the laptop, right away, I hear the familiar apple boot sound. Then the laptop continue to boot. And finally
when it finish boot, I try to use it, the trackpad does not respond, so is the keyboard. I was thinking it may had crashed. But when I press
the power button. The shutting down message appear. So I know the computer did not crashed. I plug in a usb mouse and it worked. After
I turn it off and on a couple times. The keyboard and trackpad came back to life again. Then I put up the laptop. But the next day when
I tried it again. Samething happened. But eventually they work again.
Here is what I find out. If the trackpad or keyboard don't work, they don't work at the same time, never alone and since they are both usb,
they don't show up in system profiler. I tried press shift+control+option+power, the laptop turns off. So the keyboard maybe working.
I tried reinstall the system fresh, same thing. I will say one of 20 tried, the keyboard and trackpad will work. Maybe more, not too sure.
When it work, they appear in system profiler.
 any boady knows wich is the problem in my mac
Edited by: iRobot ( )
Post Answer
Score
Avatar
rj713
39.1k
Answered
PermalinkHistory
From lack of use the connections may have built up some resistance on the connections for the keyboard and trackpad. Open up the computer and clean and remake the connections. If this doesn't work let us know and we will look further.
Installing MacBook Air Models A1237 and A1304 Trackpad Control Cable
0
Score
Avatar
Blaine
Answered
PermalinkHistory
I'm having this exact same problem. I have replaced the trackpad control cable and the top case... I fear that it is a bad logic board..
0
Score
Avatar
Austin
Answered
PermalinkHistory
I have the same issue! I purchased an A1237 MBA with a bad hinge and no sound, and have since replaced the screen and applied new thermal paste to the CPU. The keyboard and trackpad worked great, with both old and new displays, but one day, and since then , neither the keyboard, trackpad, or sleep sensor, will not work (it won't go into sleep when the lid is closed). I have replaced the trackpad control cable, but the issue persists! Something that also occurred at the same time was the system got insanely sluggish (10.6.8) and everything takes forever to load. I am able to use a USB mouse, and right from start-up the CPU is running at almost 100% with no running apps! Has anyone had this happen or know a fix?
PS Anyone have any good places to start for sound as well (no output from either jack or speaker, system profiler shows no audio devices)
Thanks
Add Your Answer
