0
Score
Avatar
lutris
11
Asked
Can the LCD be replaced?
History
Is it possible to remove the bezel around the screen to access the LCD? If it is glued on, would a similar heat-gun method as needed for the recent Macbook Pros work?
Edited by
Can anyone tell me what the part number is for the LCD panel. I'm trying to find a exact replacement.
weidyc,
weidyc, it would work better for you if you click on the link on the right side of this page "ask a question" and give as much detail as possible. I also believe that the apple guru's always ask for the serial numbers...anyhow give it a try and I am certain you will get a quick response. Good Luck
oldturkey03,
Post Answer
Score
Avatar
machead3
12k
Answered
Accepted Answer
PermalinkHistory
Best NOT
to use a heat gun... see How to Replace the Macbook Air Hinges and LCD - heat can deform the rubber trim.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
Thanks! Sorry, should have checked earlier revisions of the Air line for the answer before asking.
lutris,
Score
Avatar
Jeremy Scalpello
229
Answered
PermalinkHistory
No, the whole machine has to be taken apart!
Score
Avatar
SIMRAN
1.6k
Answered
PermalinkHistory
lutris you can remove the bezel and change the led from that . i have also changed the led . see the link :
http://www.youtube.com/watch?v=eHNtnvzfS...
be patient thnx
Add Your Answer
