0
Score
Janet
Asked
Powers up but black screen
My laptop powers up, but the screen is black.
Edited by: oldturkey03, machead3, and mayer ( )
3
Score
rj713
39.1k
Answered
Accepted Answer
Hook up an external monitor to determine if you have a logic board or LCD problem If the external monitor works the trouble is with the display or its cables. You should also double check that your memory is properly installed and you may want to replace your bios battery. I have included a link for teardown of your unit. Good luck.
0
Score
Chuck
13
Answered
The "black screen of death" is usually very easy to repair on a laptop. First turn your computer off by pressing and holding down the start button. Next unplug the computer and then remove the battery. Press and hold down the start button for about 60 seconds. Release the button and plug in the computer. Press the start button and the display should return. Replace the battery. If this does not work, try it again up to four times. No results usually indicates a bad mother board. Hope this helps.
Did a lot of searching, and by crikey oldturkey's one worked for me too just now. Seems bizarre, almost like voodoo, but this seemed like the easiest solution from all the other ones I found to try. Note: my wife pulled the battery out and it still didn't work, but I followed those instructions exactly and it's perfect now first time!
0
Score
Answered
0
Score
Answered
