The Wi-Fi-equipped Canon PowerShot SX510 HS is a perfectly capable long zoom camera.
7 Questions View all
Dropped camera and now lens won't open or close. HELP!
I dropped my CANON POWERSHOT SX510HS and now the lens is stuck part way out. Also, the piece inside the lest casing is pointing slightly downward. Is there any way for me to repair this myself??
Score 1
Add a comment
1 Answer
Most Helpful Answer
Taylor Hauck, start of by using the information from here. Even with those it is most likely that you damaged the lens drive or the lens assembly itself. Parts are almost impossible to get so you will most likely have to replace the lens assembly. Also a slightly different model, this guide should get you there.
Score 2
1 Comment:
useless guide because partial/incomplete
by
Add a comment
Add your answer
Taylor Hauck will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 1,067
