0
Score
Asked
Scroll wheel popping out?
After replacing the scroll wheel, LCD's, and batteries on several 5th generation iPod nanos, I've noticed that the scroll wheel will sometimes go back in without any problem. Other times it will go in but it wont be secure. I have been searching everywhere for a possible solution, but I cant seem to find out whats going on. I use a very thin grinded down (to be thinner) exacto knife. I start at the upper right hand corner between the menu and right button, and I work my way down giving it some pressure to pop it out. Any input on to how to get the device to sit perfectly every time would be greatly appreciated.
Thanks!
Score
slith
13
Answered
I had this problem and I've decided that the guide for removing and replacing the click wheel is not 100% correct. In actual fact, the metal bracket around the connector port at the bottom of the iPod also helps hold in the bottom edge of the click wheel. So, the correct way to remove the click wheel is to first remove the bottom plastic bit, then remove the 2 screws holding in the metal bracket surrounding the connector port (the middle and right screws at the bottom) and remove the metal bracket before attempting to remove and replace the click wheel itself.
When you replace the clickwheel, you need to make sure that as you insert the metal bracket the clickwheel is properly in place so that the bracket holds in the bottom edge of the click wheel. Simply apply a little pressure on the bottom of the click wheel as you return the metal bracket into place.
0
Score
tipoo
Answered
Did you find a solution? My scroll wheel won't go back in.
tipoo, you disassembled your Nano and the wheel wont go back in? Just trying to visualize the problem so I can help you to find an answer
I'm not sure what you mean by pop out to the back...It just slips out of the front, like nothings holding it in place.
0
Score
oldturkey0
88.7k
Answered
Try this and see if it works "I've been reading thru different posts and this seems to be a recurring problem and needs to be addressed by apple. the board/clickwhee
Good luck and let us know how its going....
0
Score
Dave
Answered
Slith,
Thanks for this extra tip. I was having the same problem. I forced the clickwheel out, but I couldn't figure out how to get it seated back in place properly. Once you remove the metal bottom bracket, you can see exactly how it is designed to hold the click wheel in.
Thanks,
David
