How do I replace timing chain
replacing timing chain need help to install
This is very complicated but the basics are remove all components in order to get to timing cover , remove old chain and replace. Make sure you line up the timing marks otherwise it won't run right. Also most of the time if your timing chain breaks you will bend a valve so check all valves hope this helps.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,076
how do i replace timing chain on my 2005 chev cavalier
by curtis
