Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
487 Questions View all
Can't disable ultra power saving mode.
After using ultra power saving mode for a while, I charged my phone and tried to disable it but there is a glitch and disable upsm option doesn't appear in the settings.
It seems as if the problem came about when I swapped to Google now launcher from touchwiz and set it as the default app when I touched the home button in upsm.
I've tried wiping the cache partition, rebooting in recovery mode and when I go into doing mode it just says that it's downloading a custom os and nothing happens on the screen for hours
Also can't back up the phone to kies because I can't use it as a USB connection in upsm. I really really need a few voice recordings from the data but the contacts etc is synced to my Google account.
Any advice?
Score 13
12 Comments
*odin mode not doing mode
by
I have the same exact problem. I would be very pleased if somebody could help us :)
by
هاتفي صقط عليه ماء ولان يشتغل ولا يشخن
by
i also have this prob its like 9 months since i didnt use again my phone with the same prob
by
It seems that My problem arise due to use of Microsoft launcher
by
Show 7 more comments
Add a comment
Most Helpful Answer
I solved that problem for my self ...
Cuz you accidentally choosed wrong launcher, you will have to change it again.
1) Go to apps and long press Google app
2)Then drag it to "app info"
3) Press "Launch as default" then choose "Delete default"
4)Then go back and press "Force Stop"
This steps helped me to solved my problem :)
Score 17
14 Comments:
Thank you! It helped me too!
by
Thank you for this procedure!!!! You are my hero!!!! :D
by
Thanks Sasopavlic, you really helped me out!
by
I can't thank you enough, thanks soooooooo much!
by
I am glad to hear that guys :D
by
Show 9 more comments
Add a comment
OK, so i found another option if the previous one did not work for you.
Step 1) On your home screen, click the apps icon. This is the icon that shows all your application in a listing format.
Step 2) Hold down on the google app (or your current home screen app) as if you were going to place the icon on the home screen. Instead of placing the application on your home screen, drag it to the section that says "app info". The application info screen opens.
Step 3) Click on "MORE" on the top right section of the screen and choose "Uninstall updates". A pop up window shows up to confirm. Click "UNINSTALL"
Step 4) Back on the application info screen, click on "FORCE STOP". Confirm the pop up window.
Step 5) Back on the application info window screen, click the "Storage" bar that reads how many "MB of internal storage used". Click " CLEAR CACHE" and confirm.
Step 6) Back on the application info window click "Set as default" and select "CLEAR DEFAULTS" and confirm. (this may be disabled by now).
Attend to go back to your home screen by pressing the home button. If you did not go back to your original "Ultra Power Save Mode" Samsung home screen, try restarting your phone.
Slide down the notification bar, and the option to "Turn off U. Power Safe" should be available.
This process worked for me, so I really hope it helps you too.
Force stopping the application alone did not worked.
Score 4
9 Comments:
Thanks, this finally worked for me. I was getting freaked out because I had just taken a bunch of great photos over the last week of vacation. You thank you thank you
by
No google app in the settings. I'm not getting any such option of the app.
by
Try to find "google app" in yours apps if this is possible... If it isn't then try to force stop all google apps you can find
by
thank you , i almost throw away that &&^&^$^ phone , will not use this mode again
by
I can't open Home Screen and Apps doesn't come up in my settings options.
by
Show 4 more comments
Add a comment
You must restart your phone and when your phone is booting to system hold volume down and enter to safe mode ,now you can turn off ultra power saving
Score 3
3 Comments:
In safe mode also no upsm please help
by
Mohamed, try this...If you have Nova Launcher on your device (mine is a Samsung Galaxy 6s Edge), that may be the reason your phone is stuck in Ultra Power Saving Mode. These steps helped ME get out of ULTRA POWER SAVING MODE... I hope it will help you, too!
1. Click on the Nova Launcher SETTINGS APP on your phone
2. Scroll down and click on SELECT DEFAULT HOME
3. Click on the HOUSE ICON that has "S" LAUNCHER on it.
4. This should reset your phone and take you out of Nova Launcher and into your normal Ultra Power Saving Mode Screen.
5. On the Normal Ultra Power Saving Mode Screen, click MORE
6. Click on TURN OFF ULTRA POWER SAVING MODE
by
I have a Samsung Galaxy S5 and the option to go into "safe mode" was the quickest and easiest way to get out of Ultra Save Mode.
by
Add a comment
If you have a samsung note 5 the only way I could get back was to make S Launcher the default.
Am not sure what helped but here is what I did.
1. Wiped system cache by powering down. Hold volume down, home and then press power. Hold till you see note 5 screen. Then release only power button.
2. Wipe cache. Reboot.
3. Goto apps. Long press on launcher. More info. Uninstall or clear defaults.
4. Press home button. This allowed me to choose launcher. I chose S launcher and ultra power savings mode setting became available to turn off.
Score 1
3 Comments:
HELLO WHERE IS THE SIMPLE STEPS FOR THIS PROBLEM AS IT HELPED ME ...
Just change the current home screen launcher to Your PHONE'S ORIGINAL Touchwiz Screen.. Long press the current launcher and drag that into APP INFO then CLEAR DEFAULT from there and DIRECTLY Press HOME button and select the ORIGINAL TOUCHWIZ screen...
by
Hey, I have a note 5. Where do I find the launcher?
by
Dear a brother,
I am facing same problem Samsung A5, I don't get Google App . Pls guide me.
by
Add a comment
Hello i use galaxy samsung a7 2016
Cant find any google app or hold the volume down + home + power, it only takes me to shut down the phone
Anybody help ?
1 Comment:
by
Add a comment
There is no ulter data saving mode in my phone
Add a comment
Add a comment
1. Hold 'Google' app down and drag into app info.
2. Click on something about default and then click 'remove defaults'.
3. Click 'force stop'.
4. Press the home button and select open with S launcher.
Add a comment
i found a really easy and simple step
1. go in to settings
2.slide down and hit screen effect
3. on saturation click natural then go back to colorful
Add a comment
Go to apps and select the Google app.
Press and hold as if you are going to place the app onto the home screen, but drag it over the “info" (i) icon.
This will take you to the Google app settings.
Scroll to the default application option and remove the app as default.
Save and reboot.
2 Comments:
My phone is Samsung galaxy j1 mini, i tried dragging the google app, but it only shows cancel and disable
by
My phone is a Motorola and it won't let me turn of ultra saving mode I have to use me phone on charge
by
Add a comment
I have a model A3 2017
NONE of these work
Add a comment
I have a Samsung galaxy j7.
I am unable to turn off upsm and tried the different methods mentioned above but none of them worked.
Add a comment
I have Samsung Galaxy Note 4 - SM-N910G & had this problem previously, BUT have successfully un-enabled ‘Ultra Power Saving Mode’ for the 1st time today after researching & comparing remedies.
*Re-enable Original Launcher (TouchWiz/ TouchWiz Easy, Smart, etc as opposed to say ‘Square Home’ /2’ as is my chosen Home Screen Launcher-launcher) &
*Authorize Administration Management (may be key as it was the difference between factory reset for the 17th time or finding crux of problem).
*Ensure Google Play Services Utility is installed, enabled & if possible update it.
1 Comment:
Please my problem is that there is password on my phone and the key pad is not show and it does not accept my finger print. I have reset the phone, am seeing Save mode but the phone is requesting for password. I need help
by
Add a comment
Mine is a samsung galaxy core prime and I’ve clicked the cheetah mobile launcher as home without knowing that i’ve turned on the ultra power saving mode. And now I’m stucked up between the settings of ultra power saving mode and the home screen with its app. Please help me.
Add a comment
Add your answer
davgnak will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 67
All Time: 46,163
