2
Score
Avatar
Dustin
25
Asked
When making calls, the other party can't hear me.
History
So, when I make a call through the handset, the other party can't hear me, but when I turn on speaker phone, they can hear me just fine. I can hear them, and the ringer works just fine.
any thoughts?
OH, and also, I can hear myself in the handset in an echo.
i have the same problem and seems to be the mic, because the sound recorder doesnt work either it seems to be a hardware problem dude!!!
ariot,
My friend has the same problem. We tried Skype Test and everything went fine. We recorded a show on tv via video recorder and it's fine so it means that the microphone is working fine. Viber is also working good. It's only when we are using the normal phone to call... The thing is that my voice is mirrored back as an echo but the other line cannot hear me. that is the problem
jamiro,
Post Answer
Score
Avatar
Garry
865
Answered
PermalinkHistory
Check to make sure there is no pocket lint in the headphone jack. Lint, dirt, and other debris can send mixed signals to the phone causing similar issues. I like to use the pro picks that I purchase from ifixit for this task and a can of air if needed.
Also, the iPhone 4 in many cases is still under warranty - it's something to always check out on newer devices.
Score
Avatar
Tesh
13
Answered
PermalinkHistory
I have the same problem, other party cannot hear my voice -intermittent - its annoying, I have to repeat myself many times. No lint in areas of concern. When I touch the phone or move in certain position then the party can hear. I purchased bluetooth aid but same problem??? cant hear me.
Try starting a new question.. This one is old an only looked at for reference. You'll get more help that way
pollytintop,
Score
Avatar
Raj
13
Answered
PermalinkHistory
Clear the small hole near the headphone jack with a very thin pin. That should make it work.
Score
Avatar
Michael Romero
13
Answered
PermalinkHistory
I scoured the Internet for a fix, and I've found a few hints that narrowed my problem down.
SYMPTOMS (With Microphone, Ear Buds, or Bluetooth):
I call and callers can't hear me.
In/Out calls work for a few seconds, then callers can't hear me all of a sudden.
All other applications that use the iPhone microphone work, yet phone app on does not.
HINTS FROM INTERNET:
Loose back glass screws.
Put pressuse on left or right bottom corners of iPhone 4.
POSSIBLE FIXES:
While testing (facing the back glass), I made calls and put pressure on the left and right sides of the bottom of the iPhone 4. Sure enough, not one could hear me unless I pressed the right bottom of the ihone 4. Once I let go, they can't hear me again. Putting pressure back on, they can hear me.
FIX (So Far):
I unscrewed the bottom two screws and removed the back glass. I pre-cut a piece of manila folder about one square inch, and layed it inside the back bottom right, and put the back glass back on. My theory is that the piece of manila folder put just enough pressure on the internal components so that I did not have to manually do it.
IT WORKED!!!!
DISCLAIMER: This is just my fix. I, nor this forum, take any resposibility for damages to your iPhone if you attempt this process.
Score
Avatar
john
13
Answered
PermalinkHistory
iPhone 4 the caller can't hear me, but i can hear them fix
try here worked for me
https://www.youtube.com/watch?v=s21dOrOn...
0
Score
Avatar
Otniel Yoreiza
77
Answered
PermalinkHistory
U mean u can't hear them or they can't hear u? iPhone 4 reported got a lot of earpiece problem. i also experienced it, and re-assembly it did fix it.
but if the problem is they can't hear u except in speakerphone mode, i think the problem is with proximity sensor...
did the screen dim automatically when u put ur phone close to ur face?
They can't hear me. didn't think to look for the dimming screen. Any other suggestions? I took apart and rebuilt this phone twice.
Dustin,
0
Score
Avatar
Otniel Yoreiza
77
Answered
PermalinkHistory
just to make sure, try to use voice recorder, if u can record ur voice properly, means no prob with the microphone... and probably the problem is with software or the proxim sensor...
0
Score
Avatar
Cristal Salgado
Answered
PermalinkHistory
When making a phone call with my iPhone4, the other party can't heard me and neither that I, once I turn it on speaker it's ok. What should I do??
cristal there are lots of posts on ifixit regarding this problem. most likely it is the microphone on your dock connector which will need replacing. have a quick look at the "solutions" under the photo of the iphone 4 on this page...
pollytintop,
0
Score
Avatar
Skip
Answered
PermalinkHistory
My problem is the caller can not hear me on speaker, everything else is just fine, when I use the phone on an app that you talk into it works just fine, what could be the problem.
0
Score
Avatar
Jason
Answered
PermalinkHistory
I had this intermittent issue where callers could either not hear me or hear static. I did a complete reload of the software and reset the network settings on the phone but the problem always came back. I finally got to the point where the problem occurred all the time so I decided to open it up. I removed the battery and the speaker/mic assembly to check for debris but I found nothing. I also could not find any liquid damage on the board. I reassembled the device and now the phone works great. The only thing I believe it could've been was that the screws may have loosened and the board was not grounded. I've seen this happen to laptops just from typical transport or movement. Just something to consider if you see this problem however if your phone is still under warranty, have Apple service it.
0
Score
Avatar
amy
Answered
PermalinkHistory
Using earbuds fixed my problem. Well, at least, it's the only way they other party can hear them. without out earbuds i can hear them perfectly fine but i'm inaudible.
Try a new dock connector to replace your microphone.
oldturkey03,
0
Score
Avatar
Louise
Answered
PermalinkHistory
I could hear them fine, but they couldn't hear me unless I was on speaker or bluetooth. It was an intermittent problem, but then more persistent.
I tightened the tiny screws at the bottom of the iphone4, as suggested above, and hooray! It is working again!
Thank you Michael Romero and Jason :)
0
Score
Avatar
Gregor
Answered
PermalinkHistory
I had the same problem after a downthrow. I heard the others but they did not heard me on a normal phone call. Free speech via Bluetooth did also not work. Then I had found these Youtube Video and -> it works fine :-) I only need even two pieces of paperboard on top of each other.
0
Score
Avatar
Jeff Johnson
Answered
PermalinkHistory
Thanks Raj, worked for me with same issue. I really appreciate your help
0
Score
Avatar
Adam
Answered
PermalinkHistory
loosen the tiny screw at the bottom part of the camera, paper didnt work for me, my opinion here is just an opinion any harm that can happen to your phone was not my fault, or if you want you can go ahead and watch the video on youtube.
Add Your Answer
Today: 18
This Week: 356
This Month: 1,522
All Time: 82,483
