2
Score
Avatar
kyle
25
Asked
NO service Signal after replacing digitizer and LCD
History
I took apart my Iphone 4 and put it back togeter fine, i thought, everything works accept for the service of phone and email. MAybe the internal antenna. I am not sure where to start.
Post Answer
2
Score
Avatar
palokiller
1.6k
Answered
PermalinkHistory
start with opening it again and checking all the connections. it probably will be just loose connector.
2
Score
Avatar
Axle
25
Answered
PermalinkHistory
There is a small metal clip underneath the battery connection. Make sure you installed it and didn't lose it. If you did install it make sure it is well centered and not touching the motherboard. I had the same problem and was able to fix it by centering that small clip.
ha! this is actually happen to me and make my signal weak after replacing housing, already thought that this small metal must have some kind of essential function, now u mentioned it, thx
Otniel Yoreiza,
Score
Avatar
Leonardo
13
Answered
PermalinkHistory
could you be more specific in which parts or connectors are?? i have the same problem but mine appear when i change the screen for the 2nd time, the first time everything worked ok
Score
Avatar
Akber Jesani
115
Answered
PermalinkHistory
check the antenna that is connected to the charging dock, also use a degreaser such as windex. Put light windex on a microfiber cloth make it very damp and gently rub it along the charging port front side where the metal prongs are and also rub it along the inside of the metal frame along the right and left edges.
I am experiencing a similar issue after replacing my lcd, i am not having issues with service or reception but i can not connect to wif. Any idea where the wifi antenna may be located?
0
Score
Avatar
jordan
Answered
PermalinkHistory
the wifi antena is the cable that is right next to the battery connection
0
Score
Avatar
Mark
Answered
PermalinkHistory
Im really confused I've tried every and the blue inductor is still on the board and the small clip is clicked in idk what to do ????
We now sell the blue inductor on the website on my profile.
Adrian Woodward,
Add Your Answer
