Complete disassembly and installation guides for most iPods, including the iPod Classic, Mini, Shuffle, Nano, and Touch.
6225 Questions View all
Stuck on the display screen is a tick & Ok to disconnect
After recharging the unit, the screen shows a tick in the centre and the text 'Ok to disconnect" none of the options on the wheel remove it and when I plug into the computer I receive the iPod message in recovery mode.
What does this mean and how can I fix it?
Add a comment
1 Answer
Chosen Solution
Try this
To reset your iPod with a click wheel, follow these steps:
Slide the Hold switch to the locked position and then slide it to unlocked again.
Press and hold the Menu and Center (or Select) buttons together until you see the Apple logo (about six to eight seconds). You might need to repeat this step.
Score 2
6 Comments:
Thanks for the fix, stopped me panicking!
by
Brilliant....worked for me ....thanks for the help. Miles.
by
It worked!! Thanks
by
Worked first time. Thank you!
by
Thank you SO much! I was so scared I’d lost everything!
by
Show 1 more comment
Add a comment
Add your answer
Christina Gray will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 107
All Time: 5,777
