1.6, 1.8, or 2 GHz G5 processor
131 Questions View all
How do I fit the hard drive temperature sensor
I have been given the above model and upon looking inside I noticed that the temperature sensor was lose. I have had a quick look and cannot see where it is supposed to be attached.
It is attached to the Hard drive casing.
Can anyone help
Score -1
Add a comment
Chosen Solution
Remove the RAM and you will see the small black Receptacle that it plugs into.
Score 2
1 Comment:
+1 ;)
by
Add a comment
Link to guide
Step 4, there you can see how the thermal sensor is placed.
Update:
I believe that the thermal sensor cable is connected to the underside of the logic board. See my comment for details.
I would remove the logic board from the case and look for a free connector on it's underside.
Score 1
2 Comments:
Thank you for your answer. However it is not the answer I am looking for. As you will see from my original question the cable is attached to the drive casing. I need to know how and where to attach it to the base unit not the hard drive case.
by
Sorry, I misunderstood your question. If you take a look at the logic board guide it looks like the cable is seated on the underside of the logic board. I would take it apart and look for a mounting point that isn't used. If the cable fit's it is probably the one. Apple dosen't usually have unused connectors on their logic boards.
by
Add a comment
Add your answer
Adrian will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,841
