0
Score
Avatar
bealdd
11
Asked
Can I upgrade from 30GB to 80GB hard drive?
History
Can I upgrade the hard drive from 30 GB to 80GB with an iPod Video?
Edited by: Chris Cline ( )
Post Answer
Score
Avatar
rab777hp
13.6k
Answered
Accepted Answer
PermalinkHistory
Basically you need this panel and this drive
Score
Avatar
Chris Green
17.2k
Answered
PermalinkHistory
yes, but you will need a backplate from an 80GB model, because the 80GB drives are thicker than the 30GB drives, but other than that, the drive should work fine. But do make sure that the 80GB drive is from a 5th generation video, not a new iPod classic, this isn't a major problem, more of a precaution.
Score
Avatar
Ben Eisenman
71.8k
Answered
PermalinkHistory
Here is the total list of what you must replace:
*60/80 gb rear panel
*60/80 gb headphone jack (it's about 1/4" longer
to reach around the thick hard drive)
*60/80 gb battery (longer to reach around HD)
*60/80 gb rubber bumpers (taller to protect logic board in thicker casing)
good luck!
Edited by: Ben Eisenman ( )
Score
Avatar
Josh Calvetti
3.8k
Answered
PermalinkHistory
Correct me if I'm wrong, but since the 80GB iPod Classic from 2007 is the same thickness as the previous generation, wouldn't its harddrive fit without need of other components?
.... You're absolutely right. They also use the same hard drive cable, so replacement is an issue of restoring, in theory. Good call!
Ben Eisenman,
Add Your Answer
