0
Score
Eduardo
Asked
Backlight flickers randomly, pressure on the keyboard helps.
Hi everyone, so I have a problem with my macbook. I don't have applecare so i'm trying to fix it myself.
Basically the backlight flickers, as if the inverter or a cable was not seated correctly. however I opened it up and reseated everything and the problem is not going away. Also If I press on the keyboard or handrest (or sometimes even typing) the screen will flicker.
Apple replaced the logic board about a year ago because of a bad nvidia chip but it doesn't look like it's the same problem, this looks more... mechanic.
Anyway, I took a video of the problem.
here,
http://www.youtube.com/watch?v=MvL6G5jju...
Please, any help would be appreciated a lot!!!
Score
Kishore
37
Answered
Connect external display, clear PRAM to set brightness to default level and verify.
Verify display listed in the System Profiler’s Graphics/Displa
Inspect and reseat the LVDS cable and camera cable connection between display and logic board. Also test if brightness setting is a contributing factor. Has flickering stopped?
Swap RAM with known good RAM to determine if video issue is RAM related..
