0
Score
Avatar
curtispsf
Asked
Won't run on known GOOD batteries. Works only on AC
History
Hi, I have 2 G4 15" 1.67ghz low res laptops. One runs fine and charges and runs on both batteries. The "bad" laptop will ONLY work if it is plugged in, even if one of the good batteries is used. I've tried all the usual things like pram/pmu resets etc but nothing works. The bad laptop also fails to charge either of the batteries although it does"RECOGNIZE" the good batteries in System Profiler.
Does this mean a bad DC & SOUND card is the problem or is there something else that could be at fault?
Thanks!
Edited by
Post Answer
2
Score
Avatar
mayer
121.8k
Answered
PermalinkHistory
I would replace the battery connector. Here's how: Installing PowerBook G4 Aluminum 15" 1.5-1.67 GHz Battery Connector
Apple part # 922-6010 Here: G4 Aluminum 15" 1.5/1.67 GHz Battery Connector
also the DC cable:
G4 Aluminum 15" DC-In Cable
Edited by
Product Image
Connects DC & Sound Card to logic board — 10 available at 9.95 each.
Product Image
Provides battery contacts — 6 available at 14.95 each.
0
Score
Avatar
curtispsf
Answered
PermalinkHistory
Thank you so much. I appreciate your help. I was told at another site that it was the logic board, but I had my doubts. I've relied on this site for instructions on how to replace the logic board on another powerbook and now I realize I should come here for advice as well!
You accepted your comment not the answer.
mayer,
0
Score
Avatar
chinby
Answered
PermalinkHistory
I would like to change your laptop battery can replace it? How to be a kind of operation?
LG Latop Battery
0
Score
Avatar
curtispsf
Answered
PermalinkHistory
I am sorry, I don't understand your response/question Chinby. Can you try saying it a different way. If you are suggesting I should replace the batteries that is not correct. The batteries are good.
Add Your Answer
