0
Score
Avatar
francesco celso
Asked
Can I replace the battery with 10-hours battery of the new MacBook?
History
my mac is the first Unibody Aluminium produced in late 2008-early 2009. I would replace it with the 10-hours battery of the new aluminium now called Macbook pro 13. Is it possible? thanks
Edited by: iRobot ( ) , rab777hp ( )
Post Answer
Score
Avatar
rab777hp
13.6k
Answered
PermalinkHistory
You can't put a MacBook Pro battery in there, however you can upgrade it to the battery from the later unibody MacBook, you can get the part here, and the step-by-step installation guide is here.
Score
Avatar
Owen Cunneely
2k
Answered
PermalinkHistory
I have replied to other questions with the same answer I am giving here. As apple releases new MacBooks the battery wattage is generally the same. The part that allows the computer to get more batter life is the fact that as Apple progresses they use CPUs and GPUs, along with many other components to allow the system to consume less power. If you had 2 light bulbs, but one use 5w per hour, and the other used 10w per hour, no matter which light you attach a battery to, the 10w light will always use more. The battery isn't the only factor that affects battery life. I hope that I am understood here. Putting a 2011 MacBook Pro battery into a 2010 MacBook Pro will not change the battery life of the 2010 model, only because that model has more power hungry chips.
Hope this helps.
0
Score
Avatar
Giorgio Piacentini
Answered
PermalinkHistory
What about a mid 2009 unibody macbook pro ?
Can i swap my old battery (~6 hours) with a new (~10 hours) battery ?
Thanks!
Add Your Answer
