3
Score
Avatar
Rob
37
Asked
Black lines are on the menu and games
History
When i turn on the wii and go to the menu small black lines appear on the tv. the lines dont make it impossible to play but do make it rather unenjoyable. i know its not the disk because it does it without any game inserted. What could be causing the Wii to do this?
Edited by: bushing and Taylor Arnicar ( )
unfortunately its not the cables ive already tried that. sorry for not mentioning that. >_<
Rob,
Post Answer
3
Score
Avatar
BWest
1.2k
Answered
Accepted Answer
PermalinkHistory
It could be one of several things, but try to narrow it down to the cable, the port, or the GPU. First try to change out the cables that connect it to the TV. See if you can borrow another cable to see if your cable is causing the issue, from a friend or a local retro game store. If that doesn't work, then try to change the cable type. If you're using component then switch to composite. At this point you should also be changing the output settings (480i, 480p) for any noticeable change.
Of note:
  1. GPU problems tend to show up as 'green spots' or 'speckling' in the picture.
  2. Issues with the AV port show up with Component output with the loss of a certain color. Red always seems to go first.
If its none of these, then you may have to go to more drastic measures. Hope this helps. :-)
==Update==
After consulting some friends, the consensus is that your GPU has bad sectors resulting in it not being able to output those lines of video. Either you can live with it, or replace the motherboard. Sorry :(
Motherboard
Motherboard Installation
Edited by: BWest ( )
Product Image
Nintendo Wii Motherboard
Ports: GameCube Controllers, GameCube Memory Cards, Sensor Bar, SD Slot, USB Ports, Power In, A/V Out — Currently out of stock.
Add Your Answer
