Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Questions View all
Question Closed
wi_fi problem, no wi-fi
Hi, my iphone 4 has no wi-fi at all, Wi-fi button is gray in color and seems a little bit of dim. no restore or update helped. the original IOS was 4.0.1 now it is 4.0.2 tried restore several times but no results. so in this case should i return phone to apple store or should i replace wi-fi module? (if possible), need your help and advice. thanks.
Add a comment
Replace wi-fi module is impossible. I think you have to go to the Apple Store
and return your phone to AppleCare warranty.
Add a comment
Hi, my ipad has no wi-fi at all, Wi-fi button is gray in color and seems a little bit of dim. no restore or update helped. the original IOS now it is 4.3.3 tried restore several times but no results. so in this case should i return phone to apple store or should i replace wi-fi module? (if possible), need your help and advice. thanks.
Edited by
1 Comment:
ahmed, right now it looks like you are answering a question about an iPhone. you need to click on the link on the right side of this page "Ask a question" and give as much information as possible. That way people see that you are asking. My suggestion would be to take it to Apple if you have any kind of warranty left. It is better to have it fixed by the manufacturer if you have the warranty.
by
Add a comment
wtf? my iphone 4 has the same problem. its totally non resposive to the touch when trying to turn on the wi-fi.resetting it several times did not work. turning airplane mode on and off several times did not work. reset factory settings did not work. i went to apple support and they seemed cluless of such a problem and offered no solutions. youtube video showed how to repair the wi-fi module using tinfoil and a soldering iron, but no thanks im not doing that. anyone have any other solutions?
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 6,711
