0
Score
Avatar
Cassie
Asked
Water Damage
History
my son spilled juice on my macbook pro, the keys are stiffish and the mouse click pad doesnt work, im able to plug an external mouse in but i think due to the damage of the internal mouse it selects things randomly. other then that the computer works fine(im typing on it....) what parts would i need to repair it because if i send it back to apple and any apple service stores they would charge me $1300.
Edited by
Post Answer
2
Score
Avatar
BigO
217
Answered
PermalinkHistory
Go to your system preferences for "Universal Access" and on the "Mouse and Trackpad" tab, check the box for "ignore trackpad when mouse is present". Screenshot here:
http://www.tkjune.com/2008/11/07/enabled...
Unfortunately, thanks to the "unibody-ness" of this model, the keyboard and trackpad are built right into the upper case of the laptop. To replace it you have to pretty much completely dissasemble the entire machine. iFixit classifies this repair as "very difficult" though it can be done. You would need to buy the top case in order to do it, and paying someone to do it will be expensive because of the challenge of the task.
If disabling the trackpad brings your mousing back to normal then it sounds like the only other problem is the sticky keys on the keyboard. If you are careful, the tops of the keys can be taken off of the laptop without taking the whole thing apart. You need to be very careful with this as they are easy to break, but you may be able to take the bad ones off and do some (very careful) spot cleaning to keep them from sticking.
--O
2
Score
Avatar
stevem196999
25
Answered
PermalinkHistory
You DO NOT have to disassemble your Macbook Pro. Just go to Radio Shack and purchase a can of NON CONDUCTIVE COMPONENT SPRAY and spray down the keyboard and everywhere that you can find an opening. Don't worry, remember it's NON CUNDUCTIVE Spray which means that electricity can not discharge so all of your internal components whould be safe. I recently had the same issue with my 2010 Macbook Pro i7 which you already know cost a small fortune. I used the spray and allowed the MBP to rest for 1 hour preferably in a warm location and that was it..Keyboard works, mouse pad works, usb works...Don't pay Apple $1200 for something you can do for your which cost only $12 per can.
I would not recommend this procedure. Disassemble the unit and clean it properly so no damaging residue remains.
rj713,
Score
Avatar
lemerise
16.2k
Answered
PermalinkHistory
The keyboard should be replaced and that means that the MBP top case must be completely taken apart to reach the keyboard. You will then be able to clean all internal components that had juice spilled on and test them. Since juice contains sugar it will take a good clean up and you'll be lucky if the logic board is intact. I hope it is. Was it a full glass of juice or just a small spill ?
0
Score
Avatar
Cassie
Answered
PermalinkHistory
thanks you soo muchfor the help!!!
0
Score
Avatar
Leo Bodnar
Answered
PermalinkHistory
I suggest you stop using your MacBook immediately, disconnect the battery and charger until you can clean the logic board.
It's a typical story...
1) liquid spill
2) panic
2) Oh, it works! Panic over.
3) it stops working after 2-3 weeks
4) by this time permanently energised power supply areas on the logic board are corroded beyond repair
You need to clean your logic board immediately. Good wash in hot water and 24h drying should be OK.
Edited by
0
Score
Avatar
Cassie
Answered
PermalinkHistory
so i literally take the logic board out and put it in hot water????
0
Score
Avatar
Cassie
Answered
PermalinkHistory
okay i just took apart the computer, thank god the logic board isnt sticky at all, i just need to get a new upper case...
Here it is! Ideally, you will be fine with just a replacement upper case.
Ben Eisenman,
0
Score
Avatar
machead3
12k
Answered
PermalinkHistory
This should be a sticky or a hot link What to do about liquid on/in device.
Good Luck,
N.
0
Score
Avatar
czamobile
11
Answered
PermalinkHistory
Hi ,i have done with my uni almost the same what you advise and it works!But after a while unit want shuts off,it just do restart,then after one week a have screen turns smoke black color(,from upper right down left corner. Then after one day it want turns on.Done.
Add Your Answer
