Score
Avatar
Neil Sinclair
57
Asked
No Power on Mac Pro
History
My Mac Pro will no longer power up.
It seems completely dead and will not
even show the power led when trying to power up.
I've tried a Reset holding the power for 5 secs
to reset the PMU but no joy.
Any help appreciated
Edited by: machead3, pollytintop, and rj713 ( ) , machead3 ( )
Post Answer
Score
Avatar
Neil Sinclair
57
Answered
Accepted Answer
PermalinkHistory
Power Supply dead! Replaced and happy bunny again|!
I take it you had the fans syncing software.
mayer,
2
Score
Avatar
mayer
148.6k
Answered
PermalinkHistory
According to which MacPro you have, there is probably a 3.6 volt AA Lithium battery. It looks like this: http://www.frys.com/product/2977135
I would replace that first. This is most likely a power supply issue and not a logic board issue. Here is a discussion on your problem: http://www.blograndom.com/blog/2007/11/c...
Do not replace the power supply unless you have the original system installation disks as they contain a program for syncing the fans. If the sync is not done the fans will run wild. If you can let us know about the battery and any symptoms at all it would help. There are specific tests for the lead out on the power supply and how much voltage each lead should have. If you want or need to go that far let me know.
Exc answer +
rj713,
Score
Avatar
machead3
21.3k
Answered
PermalinkHistory
Try a different power cord
try a different battery. If neither work suspect logic board. If one works suspect the other power connector (DC in or Battery)
If this answer is acceptable please return and mark it.
Good Luck,
N.
Thanks, its a Desktop Mac Pro, are you suggesting the Pram Battery?
Neil Sinclair,
0
Score
Avatar
kuz
Answered
PermalinkHistory
Mayer i have a similar problem, i have the mac pro 1,1 quad 2.66. it kept crashing and then today it just died, no lights come on the logic board when i plug in the power cord, not even after u pressed the SMC reset or the one above. would that be all connected to a fried power supply or should try the battery??
Please start a new question as other will not look at this one since it's been solved. thanks.
mayer,
Add Your Answer
