Score
Jason
13
Asked
Took apart MBP 13" to clean keyboard spill, now display not working
Hello,
Thanks to anyone who can provide assistance to this problem. This post might be a little long, because it is the result of a long 12 straight hours of my life. I am experienced in PC repair, not too much on laptops though. And this is my first time using apple computers ever.
A couple of weeks ago I bought a new refurbished Mac Book Pro Unibody 13" (the new model that can output Audio via HDMI).
Yesterday, while at the office, I accidentally tipped over a cup of orange juice right into my keyboard. Yes, it was Friday the 13th. Coincidence?
The laptop shut off when this happened, and I tipped it upside down to drain out some of the liquid. After wiping it up as much as I could with paper towels, I took the laptop home and dried it out with a hair dryer for 20 minutes, did a little more cleaning, then turned it on.
To my astonishment, it turned on and it seemed all the ports were working, the only issue seemed to be the keys were a little sticky, and the backlighting was off.
Reading posts here and across the internet, it recommended I disassembled the MBP to ensure that any leaked orange juice is cleaned up so it would not corrode the unit, reducing the life span. Plus, the keys were sticky and I wanted to clean up as much as I could.
Following the guide here on iFixit, I disassembled the MBP to the bottom of the keyboard and wiped it all down. I found a bit of orange juice and sticky material on random spots, but it seemed to miss the key items - the CPU, superdrive, hard drive, ram, CPU fan. I cleaned what remained on the underside of the keyboard, and popped off the keys on top that were sticky while typing (they were on the left side of the keyboard, where the juice spilt). Under the keys, I could see some orange spots/sticky residue where the orange juice was. The trackpad was in good shape, it seems like it just hit the keys on the left hand side and a tiny little bit seeped down and got on the battery and a few other spots (a tiny tiny bit on the logic board, some on battery, some on case, wasn't much though).
I cleaned up with lysol wipes and 99.95% isopropyl alcohol every spot on the case, logic board, anywhere where I could find any orange juice. I gave the logic board a good cleaning and it looks like it is in fairly good shape.
Then...I reassembled.
After reassembling the unit and screwing everything back together, the display would not come on! :(
I do not believe the LCD itself is damaged, but perhaps the connector might be. (Either on the logic board side or on the connector side, not sure how to tell)
Funny thing is, I was more nervous about removing the keyboard cable than the video cable I removed. I felt I did a fairly safe job removing the video cable, it didn't feel like I broke it when I disconnected it originally, but who knows...it's not working.
After reassembling, I could press the power button, and everything would turn on - I'd hear the hard drive spinning, but no display. Hooking up my MBP to my VGA monitor, however, I could get a display.
So, I turned over the computer to keep working on the problem. And after disassembling this time to work on the problem again, I think I messed up the camera cable from all the constant unplugging and replugging in multiple times. I could see one of the little pins on the end of the camera cable was bent and fell off. I most likely bent a pin on the camera connector when I was trying to reinsert the camera connection into the motherboard.
So, after reassembling the second time, the power would not turn on with the camera cable disconnected. After clearing the bent pin and reinserting it into the motherboard, the machine turns on - I didn't even have to press the power button, the machine turns on by the act of inserting the camera cable on the logic board; in fact, this is the only way to turn it on now, by inserting the broken camera connector into the motherboard, the machine will turn itself on. And, I have to have the machine plugged into AC power to make the machine turn on, but if it gets started, then the machine will still run if I remove the power cord by battery power. Then, I can shut down the laptop by removing the battery cord from the motherboard.
If I leave the Camera cable connected after the machine turns on, the camera cable starts getting really really hot - so I disconnect it immediately after getting the machine started. I think with the broken pins, it is messing up the power regulation on that cable and somehow is shorting something out and causing it to build up heat improperly.
The display still will not work even though the machine still will boot by ghetto rigging it. So, of course at this point I figured what do I have to lose and kept messing with it. I kept plugging in and disconnecting the video (believe it's the LVDS) cable on the motherboard to make sure it had a good fit. After plugging it in and out for about the 20th time to ensure I have a good fit, I pulled a little hard to ensure it was properly seeded and that little bracket on the LCD cable that helps you remove the cable popped off. But, it still looks like all the pins and everything are still there, and should be working, it plugs in snug and stays in the motherboard. I don't know why the video stopped working in the first place, it worked fine before I ever took apart the laptop!
This is where it stands now, and I'd like some opinions on what I should do...if I can repair it myself at this point, if it's going to be worth it to take it to the apple store/authorize
To turn the machine on now, these are the steps I must take:
1. Connect the AC cord (it will not turn on just by battery alone).
2. Plug in the broken camera connector cable into the slot on the motherboard, and the machine instantly turns on (without pressing the button on the keyboard)
3. If the battery is in, I can remove the AC adaptor and the machine will keep running. If the battery is disconnected, removing the AC shuts down the machine instantly.
Here are pictures to help my diagnosis:
1) http://www.electricenlightenment.com/MBP... [this shows an overview of the motherboard. Please confirm that I am correct, that the circle highlighted is the LVDS connector & camera connector]
2)
http://www.electricenlightenment.com/MBP... [this picture shows the step of plugging in the AC adaptor to initiate the power on sequence]
3) http://www.electricenlightenment.com/MBP... [this shows a close up of the LVDS cable after I knocked the clip off that helps you take the cable off. But, the LCD stopped working while that was still intact. As you can tell, it is fully plugged in. Don't know why it's not displaying any video.
4)
http://www.electricenlightenment.com/MBP... [this shows a close up of the camera cable with the bent pins. As soon as I plug this in the camera cable connection port on the motherboard, the machine instantly powers on]
I appreciate any help on my predicament!
Thank you,
Jason
