0
Score
Avatar
matt
85
Asked
Can I put a faster processor
History
Can i put a faster processor in my macbook 13" late 2007 model it has a 2.2 ghz core 2duo 2g of ram in it now. and i want a faster processor what can i do?
Update
Thanks for all the help i think ill stick to 2.2ghz that i have now sounds like alot of work and not enough time in my day to do it.
Edited by
Post Answer
Score
Avatar
Matt Barnes
6.6k
Answered
PermalinkHistory
After a bit of searching I found that you probably can upgrade your logic board to a 2.4 GHz logic board without having to swap many, if any, parts. It looks like all the parts that are compatible with the 2.4 GHz Penryn logic board are the same parts you have in your MacBook Santa Rosa.
Update
We don't have an extra Penryn logic board laying around that I can throw into our test computer, but I did look at the parts compatibility list between the Santa Rosa and the Penryn, and all these parts are cross compatible:
  • Display Assembly
  • RAM
  • Upper Case
  • Hard Drive Cable
  • Optical Drive Cable
  • Airport Card
  • Lower Case
  • Fan
  • Battery Connector/Sleep Sensor
  • Heat Sink
  • MagSafe Board
  • Bluetooth
  • Left Speaker
  • PRAM Battery
  • Right Speaker
So the logic board should be swappable without any compatibility trouble. Please check my list to make sure I didn't miss anything.
Edited by
Product Image
MacBook Core 2 Duo 2.4 GHz Logic Board
2.4 GHz Motherboard / Ports: Mini DVI Video Out, 1000BaseT Ethernet, Firewire 400, 2 USB 2.0, Audio in,... — Currently out of stock.
Please Keep us posted Matt.
Majesty,
0
Score
Avatar
remacberlin
7.3k
Answered
PermalinkHistory
To my knowledge the Penryn and Santa Rosa boards are not interchangeble. They have different connectors on the logicboard, the fan and bottom case are different also. Anyway the difference in speed between a 2.2GHz and a 2.4GHz machine is hardly notacible. I'd stick with the 2.2 or sell it and buy a really faster machine, like one of the new MacBook Pro line.
You may be right remacberlin, but as far as I know all the connectors for the fan, uppercase, hard drive...etc are the same on the Penryn and Santa Rosa. Also, I think the lower case is the same. I will do some swapping parts with our testing computer to see what I can find out.
Matt Barnes,
Please keep us updated.
remacberlin,
0
Score
Avatar
matt
85
Answered
PermalinkHistory
Add Your Answer
