Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Question Closed
My touch screen doesn't work.
My iphone 3gs was broken,and then i placed a new front panel including:new glass screen and new digitizer together with home button ,speaker etc. So when i put all together, everything was fine but the touch screen didn't work at any finger touch. I've been trying many times connecting and disconnecting the front panel looking for the solution but nothing work.
1 Comment:
Do you have the answer for me, cause I'm facing the same problem!
Thank you very much!
by
Add a comment
1 Answer
I had the same problem, like some one said, you have to power off the Phone first, if you forgot to, you can leave it on for a few days till the battery dies then charge it and it should work or take it back apart and disconnect the battery, put it all back together and after you have the screen connected, turn it on by holding the power button for a few seconds and it will work
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 18,730
