0
Score
Avatar
Peter Bierman
Asked
July 2010 27" iMac has 2 or 3 internal SATA connectors?
History
Does the July 2010 27" iMac have two or three internal SATA connectors?
I'm wondering because it can be purchased with three internal SATA devices: a 3.5" HD, a SSD, and an 8x SuperDrive.
What about the Late 2009 27" iMac? Is there an unused SATA port in there?
Edited by: Walter Galan ( )
Post Answer
Score
Avatar
Jason Keller
25
Answered
PermalinkHistory
Although quite widely stated, as I know from my own searches for information on the subject, the above answer is quite wrong. The July 2010 27-inch models have three inboard SATA connectors (though not the 21.5-inch models). The third port is difficult to reach, but by no means impossible if you're handy with suction cups and a torx driver. If you don't have the 2010 27-inch iMac built to order with an SSD from Apple, you'll be missing some necessary cabling and a mounting bracket, but there are ways around that. I'd suggest checking out the following.
http://eshop.macsales.com/shop/turnkey/i...
http://ssd.youds.com/
I upgraded my own 2010 27-inch with a third-party 2.5-inch SSD using the second site as a guide for parts and procedures.
The 2009 27-inch iMacs do NOT have the third SATA port with which the 2010 models are appointed.
Hope that helps!
0
Score
Avatar
nick
15.3k
Answered
PermalinkHistory
No
it has a connector for the HDD and DVD drive
if you want 2 HDDS, uyou need a converter to do that
How does the new 27" iMac support three drives then?
Peter Bierman,
0
Score
Avatar
David Fiala
Answered
PermalinkHistory
"The 2009 27-inch iMacs do NOT have the third SATA port with which the 2010 models are appointed."
OK, just realized this after tearing my 2009 27" iMac apart.
So much for being way over psyched to get my iMac an SSD drive...
Thought the connections for the port are there... Just no port soldered.
Any idea wether they are live and let's say I can manage to install the port - would it work?
The 2009 and 2010 models may be different. Would you give your EMC number located on the bottom of your stand? Thanks
mayer,
My 2009 iMac has the EMC 2374.
David Fiala,
I just got in a 2010 27", 2.8 GHz Core i5 and it's EMC 2390 but still A1312 This may get confusing because the 2390s include a core 2 duo, i3 & i5
mayer,
0
Score
Avatar
sack
13
Answered
PermalinkHistory
any news on this?
Add Your Answer
