2
Score
Avatar
randy3833
393
Asked
What do I replace the original thermal materials with?
History
I am reinstalling my recently repaired logic board in my G3 900mhz iBook 14". The original thermal heat transfer materials on the heat sink were two preformed squares, the larger was a blue foam looking square, the other smaller one was gray and seemed to be a more solid version and consistency of thermal paste. Can I use the normal Arctic Silver paste for the installation or do I need to find the same type of original squares?
Thanks,
Randy
Edited by
Good question +
rj713,
Thank you, I'll give that a go. Randy
randy3833,
Post Answer
2
Score
Avatar
Matt Barnes
6.6k
Answered
Accepted Answer
PermalinkHistory
Arctic Silver Thermal Paste will work great om the heat sink in your laptop.
Product Image
3.5 gram Arctic Silver thermal paste tube — 50+ available at 8.95 each.
Thanks. Do you have a recommendation for the thickness of the paste? The iFixit instructions say to spread a thin layer. The original materials were fairly thick, maybe up to 1/16th of an inch.
randy3833,
My experience in the matter is that it's better to have a bit too much than a bit too little. You just really need to make sure you don't have any that comes out over the edges / spills out when you reapply the heat sink. 1/16 " sounds fine to me, I just like to make sure I can't see the processor any more through the thermal compound.
Taylor Arnicar,
Add Your Answer
