0
Score
Avatar
marianne
Asked
The slide to unlock has stopped working
History
Hi
The slide to unlock the phone has stopped working, in fact the touch screen has basically stopped working, is this a common fault and do you know if it can be fixed please.
the model is an 8GB 3G iphone.
thank you
Marianne
Edited by: markus weiher ( )
"common" might be the wrong word for it - but yes - it happens. did you drop the phone? fluid damage?
markus weiher,
Post Answer
0
Score
Avatar
pollytintop
39k
Answered
PermalinkHistory
try hard reset first and restoring iphone before replacing...it's cheaper
but could be digitiser has broken if you dropped iphone. see ifixit repair for this part Installing iPhone 3G Front Panel
0
Score
Avatar
iDeibi
Answered
PermalinkHistory
hi,
i had the same problem with the Touchscreen, because one of the ribboncables didn't wont to work. I tested several positions for the cable and after 3 hours of testing i got it work. Sorry for my bad englisch. (I don't now if it was cable 1,2 or 3 but all of these cables has to be in a perfect position to work).
If this solution didn't work you can try to clean the contacts of the three cables (be careful because you will have to clean it with liquidcleaner, it can broke your whole iPhone). And then dryness the contacts with a Hairdryer, but be careful, the iPhone should not get warm, so only use a low heat.
I hope i could help you a little bit.
Add Your Answer
