4
Score
Avatar
David Bambury
49
Asked
How can I extract a disk stuck in the drive?
History
Software ejection does not work.
The Disk help application finds the disk, but its 'eject' button is greyed out, and it displays a notice
"waiting for drive"
Does the optical drive show up in System Profiler?
rab777hp,
To rabb777hp, Thanks. Yes the drive showed up, and the disk too, in 'disk utitlity', but the disk was never read. Thanks for anyone else who tried to give advice. The problem was solved using Terminal, and entering the command drutil tray eject. The mystery remains why this one disk would not eject using the eject button, or more 'user-friendly' software eject routines.
David Bambury,
Are you using leopard or snow leopard? If I remember correctly, leopard has some software bugs with ejecting and unmounting volumes and disks.
Robert Ciaccio,
Thank you all who have been so helpful. I now have so many solutions to that problem that it's difficult to decide which to use....that is if it ever happens again - which it has not!
David Bambury,
I have the same problem as you do. However, I have two CDs stuck inside and every time I turn on laptop it makes strange noise. Near me there is no Apple store and no one else doesn't know how to take CDs out.
Sonja,
Show 2 more comments
Post Answer
2
Score
Avatar
James
25
Answered
PermalinkHistory
I also had problems with that. I'm not sure why but I found that holding down eject and esc buttons while the computer restarts will eject the disk every time.
Score
Avatar
palokiller
1.7k
Answered
PermalinkHistory
another way, how to get the disk out is:
restart your computer, right before you hear chimes, hold down your mouse button. hold it, until it spits out the disk...
it works when you have unreadable disk in your drive and youre trying to boot up your computer. i have tried it myself, it works...
Thank you calvera and palokiller for your help. Interesting that leopard has software bugs affecting disk routines - little in life is ever perfect, is it. That's what makes things interesting. So. I now have two methods of overcoming the problem should it ever surface again - which strongly suggests it never will. Thanks again.
David Bambury,
Score
Avatar
Mickey
13
Answered
PermalinkHistory
I actually had to go in and extract it manually. But the real problem was that the bezel, the thing that lets it slide in and out, it was bent so, if you can follow the steps to get that out in the guide section, and try to see if the thing is bent, if so, just be fragile, and bend it back into place.
Add Your Answer
