Score
Dian
13
Asked
Why is my computer shutting down for no reason?
My aluminum MacBook is about 2 years old now. I use it very often, so perhaps this is just normal? It turns off randomly, without warning, with more than enough battery power left. It's happened 4 times in the past month or so and I'm beginning to get worried! It just happened today, after I unplugged my adapter for about 15 minutes. I left the computer off for 4 hours. When I returned to it, I plugged in the adapter and turned on the computer...turn
Here is what my System Profiler says about my Power:
Battery Information:
Model Information:
Serial Number: DP-bq20z951-3a2c-4a24
Manufacturer: DP
Device name: bq20z951
Pack Lot Code: 0000
PCB Lot Code: 0000
Firmware Version: 002a
Hardware Revision: 0005
Cell Revision: 0100
Charge Information:
Charge remaining (mAh): 2338
Fully charged: No
Charging: Yes
Full charge capacity (mAh): 3245
Health Information:
Cycle count: 551
Condition: Good
Battery Installed: Yes
Amperage (mA): 385
Voltage (mV): 12293
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 15
Disk Sleep Timer (Minutes): 10
Display Sleep Timer (Minutes): 15
Automatic Restart On Power Loss: No
Wake On AC Change: No
Wake On Clamshell Open: Yes
Wake On LAN: Yes
Display Sleep Uses Dim: Yes
Battery Power:
System Sleep Timer (Minutes): 0
Display Sleep Timer (Minutes): 0
Reduce Brightness: Yes
Hardware Configuration:
UPS Installed: No
AC Charger Information:
Connected: Yes
Charging: Yes
Thanks for reading!
Score
Taylor Arnicar
7.9k
Answered
This sounds like it could be an overheating issue. Has it been rebooting after you've been doing particularly graphics / cpu intensive processes? Watching online videos or playing games would be two fo the big ones. Older computers tend to accumulate dirt, dust, etc inside them after that long of a time. My first recommendation would be to clean out the inside of your computer.
To find out what kind of MacBook Pro you have, you can use our ID-Your-Mac tool. After you know which model you have, you can use one of our appropriate guides found from [[Family:MacBoo
When you open it up, try using some canned / compressed air to blow out and remove the dust you're likely to find. Hopefully this will improve your situation. :)
+ Great details on the question!
Taylor Arnicar,
