Score
Avatar
Thomas Brodin
13
Asked
Doesnt turn on anymore, need new power supply?
History
Hi, I have an old G4 / DP 450 Mhz . A few days ago, the circuit breaker of my appartment went off a few times because of using too much power (Old installation). Afterwards i couldn't turn on the computer anymore. I understand it might be the power supply. Can you advice me on what to do? Do you have those part available at the store, how much it would be?... I'm trying to see if it's worth saving this old machine... Many thanks in advance for your precious advice and looking forward to hear from you
Edited by: David Hodson ( )
Post Answer
2
Score
Avatar
mayer
148.8k
Answered
PermalinkHistory
First i would check to see if you are getting power to the wall outlet. Also try to determine what other things are drawing power from the same circuit to see if you are overloading it. Try a different outlet that draws power from a different circuit than the current one. Do you smell anything burned? Does it blow the circuit as soon as it's plugged in or when you turn the power on? Here is an exploded view of all the parts for your machine with the part numbers: http://ep.yimg.com/ca/I/lovemacs_2113_37...
Beat me again. +
rj713,
Score
Avatar
Phil
13
Answered
PermalinkHistory
Try this link to see if your power supply is faulty : http://docs.info.apple.com/article.html?...
I have the same computer and my second power supply died in it this week. After opening up the power supplies I found some cracked resistors (actually the same in both power supplies). I'm waiting for parts right now... I'll keep you posted when I'm done replacing them. I might as well write a guide to help other in that situation.
Since this computer has gone vintage, it's quite hard to find a power supply for it... You may want to try eBay or classified adds.
0
Score
Avatar
nick
15.3k
Answered
PermalinkHistory
You might need a PSU but, check the power connector that it plugs into on the logicboard first
If you google what computer you have, you can find parts and a guide
ebay is a good place for parts
Add Your Answer
