0
Score
Dor
Asked
iPhone won't turn on after screen replacement
I replaced the glass+digitizer everything went well no problems at all but when i finished in noticed the screen won't turn on. what could go wrong that would cause this?
The lcd had lots of burnt pixels so it may be dead but i don't know if just opening the iphone killed it...
please help
thanks
2
Score
markus weiher
21.4k
Answered
2
Score
Julie Rhoden
25
Answered
I just replaced my cracked screen and had the same issue. mac forum suggested to reset the phone (hold down the home button and the power button simultaneously until apple pops up) and it worked like a charm!
Score
webifixit9
13
Answered
I've got the same problem. I can tell the phone turns on because the silent/noisy switch runs the vibration motor when I switch it to silent. It shows up in iTunes as well. The buttons are ok, because holding down "home" and "power" shuts the phone off. Other than that, nothing. Tried restoring in iTunes, nothing. Have tried re-seating the cables 2 or 3 times. Do I need a new LCD (it was fine before the glass/digitizer replacement)?
0
Score
stephen
Answered
I replaced the complete digitizer screen, screen not opening , followed your instructions to reboot I can only slightly see the apple ,
I connected to my computer it does recongise it, also the screen is open but very dark can barely see but it on?
what can I do ?
Update
by the way screen brightness is on full
did you connect cable 3? that ones very tricky to get and it usually makes it so you can see the screen
mark,
I tried the wall charger and connecting to my computer nothing works the cables are seated perfectly
Dor,
i would connect the iphone to the computer and try to put it into dfu mode (click here for a video) - maybe this gives you any sign of life
markus weiher,
