2
Score
Avatar
Sarah Smith
25
Asked
Backlight gone after suspected water damage?
History
I have a 2g ipod touch that has probably had water damage. My sister claims that it has never been submerged has but both the internal and external sensors are tripped. Everything is working fine except the backlight will not turn on. I tried swapping out the LCD screen but that did not solve the problem. I've taken out the logic board and cleaned it all and there are no obvious corrosion spots. Anyone have any suggestions?
Edited by
this just happened to me today. you're better off just leaving it be and getting a new one. thats what im doing.. there is nothing that you can do at this point.
Cassidy,
Post Answer
2
Score
Avatar
jonathan
55
Answered
PermalinkHistory
I work on broken iPods all the time and we get water damaged iTouches in all the time. The backlight is built into the LCD and we'll try an LCD but the vast majority of the time, there is some kind of short in the motherboard that affects the backlight circuit. Your situation sounds all too similar...there isn't anything you can do at this point, I'm sorry to say.
Edited by
I had that issue with an iPhone 3G in water. At first, I said it was the LCD. Then I've tried putting it's logic board into a working iPhone and I've had THE EXACT SAME ISSUES. So, sadly it's the logic board! :(
Panos Skoulaxinos,
0
Score
Avatar
Dean
31
Answered
PermalinkHistory
try reseting it or putting it in dfu mode and restoring your ipod. search how to put your ipod into dfu mode if you dont knwo how
sry about the spelling my keyboard keys are small
Dean,
good luck fixing your ipod
Dean,
0
Score
Avatar
crevz
226
Answered
PermalinkHistory
There is actually something you could do, but it takes some serious soldering skills from what i gather. The "6R8" coil is most likely fried, you can find them on eBay and other suppliers for about 15 bucks, but like i said its soldered on the logic board. Google 6R8 and youll get some hits.
I agree with joseph. I bet the coil got shortened out. You really have not much to lose by trying to fix it, steady hand some good magnifying lights and you might get it accomplished
oldturkey03,
I have the exact same problem with my 2nd generation. i am going to try the soldering thing if i can find this 6R8 coil. if it works i will be sure to tell you how it went.
Brian,
Add Your Answer
