The PlayStation 3 Slim is the second version of the PS3 video game console with the original model number CECH-2000. Produced by Sony Computer Entertainment it fixed many issues of the original (fat) Playstation 3. It was released on September 1, 2009.
469 Questions View all
Why won't my PS3 stay on
My PS3 won't stay on. I was playing assassins creed 2 & it froze. I turned it off & turned it on again but now it won't boot up properly. I tried the reset by holding it down for 10 seconds but instead of the beeps I'm supposed to get, it just powers off & if I leave it on without holding down power button, it turns off after about 30 seconds
Score 1
Add a comment
Most Helpful Answer
This type of behavior is usually caused (at least initially) by heat. After a while, the heat compound on the CPU breaks down and is not able to transfer the heat from the CPU to the heatsink properly. This leads ultimately to overheating. Once this happens, all bets are off. Most likely, the CPU overheats right away which is why the system shuts down. Start by replacing the heatsink compound and to run the system again.
Let us know how you make out...
Dan
Score 1
Add a comment
Same problem here. Did y'all find a solution?
Add a comment
I believe that it may be a power-supply problem, which causes it to lose power after a few seconds when the HDD activates.
Add a comment
Add your answer
stephenmurphy28 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 672
