0
Score
Avatar
Brendan
Asked
Flickering Screen, horizontal lines, varies in degree of severity
History
I have noticed in the last week that my screen has flickering horizontal lines that appear on the screen. When using the web, the problem becomes worse and often turns the whole screen dark gray / black.
Is there a fix for this that I can do myself? Possibly a loss video cable or something? As for having it repaired, it may not be worth the cost.
thanks
Post Answer
2
Score
Avatar
lemerise
16.2k
Answered
PermalinkHistory
You say <<When using the web, the problem becomes worse and often turns the whole screen dark gray / black.>>
This symptom looks like a failing GPU (heat generated by streaming video on web). I would connect the PB to an external monitor and check if the video is normal on the external. If yes then the GPU is OK and the LVDS cable may be bad.
+ a distinct possibility
mayer,
To test the GPU, plug into an external monitor, if the screen on the monitor starts doing the same thing at the same time as the Book, that will confirm it.
mayer,
Score
Avatar
mayer
121.8k
Answered
PermalinkHistory
The most likely villain in this is the Display Data Cable (LVDS cable). Try moving the screen up and down and watch for greater activity of the lines while doing so. If it acts up then you need to replace the cable.
Here's the part: http://www.ifixit.com/PowerBook-Parts/G4...
Here's how to do it: Installing PowerBook G4 Aluminum 12" 1-1.5 GHz Display Data Cable
Edited by
+ comprehesive answer
remacberlin,
0
Score
Avatar
beaniesteadman
Answered
PermalinkHistory
I am trying to fix my mum's laptop which currently has the same problem. My Dad thinks it is the ribbon connector. Do you know where I could buy one of these and/or how much it will cost me? Thanks.
Also if anyone has had this problem fixed them please let me know!
G.
Add Your Answer
