3
Score
Avatar
Kyle Wiens
8k
Asked
iPhone keeps losing service after I dropped it
History
I dropped my iPhone 3g the other day. Now it keeps losing service off and on sometimes it gets service and I can get text messages and make calls, but then loses service in like 30 seconds even though I haven't moved it. My phone is also jail-broken for t-mobile.
Please help me out; my wife is super mad because I just got this phone after I broke my other one.
(This is a question asked by Steven from our discussion forums that did not get an answer. We'll see if you guys can help!)
Edited by: Sterling Hirsh ( ) , Nat Welch ( )
I have 3g 16gb iPhone. I can hear from the phone the speaker and headphone works. all other functions works.
George Tola,
Post Answer
5
Score
Avatar
tlcgraham
91
Answered
Accepted Answer
PermalinkHistory
Sounds like a loose connection for the antenna.
2
Score
Avatar
wtylko
131
Answered
PermalinkHistory
Every time you lose service, a much faster way to get service is to turn airplane mode on and off. Also, have you updated your iPhone to the latest software? If you haven't you should do it. And if all this does not work, try restoring your iPhone and get it swapped out at the genius bar. But don't tell them you dropped it. They have no way to find out! Also un-jail break your phone before you take it there.
Edited by: Sterling Hirsh ( ) , wtylko ( )
2
Score
Avatar
frode
25
Answered
PermalinkHistory
The problem is a loose cable. Open the iPhone through iFixit steps and reconnect the cables and you are fine.
I have fixed a lot of phones this way with the same problem.
Edited by: Nat Welch ( )
Remember kids, good spelling and grammer saves lives.
Nat Welch,
2
Score
Avatar
josh tanner
25
Answered
PermalinkHistory
Depending on your current firmware, updates also update the radio's baseband. I was having the same problem for a while until i did a full update. Carriers will always change their network configurations to increase their data speed. Also before you do so, back up your files and do a complete reset all settings from settings/general/reset all settings. It will take about an hour. This will erase any registry file value that could be causing the issue. Hope this helps.
Score
Avatar
mobileease
37
Answered
PermalinkHistory
When you dropped your phone i think you have damaged your mother board. I had an incident with my iPhone 3G and now it will only pick up 3G signal. Take it to an Apple store and see if they will replace it for you. I don't think there would a DIY solution for this.
Score
Avatar
Beatrice B
13
Answered
PermalinkHistory
I had the same problem and had to replace the antenna and antenna flex.
It takes a lot of patience to do it, but it works fine now!
total cost: €20 (or 30 dollar something)
Score
Avatar
Martin
79
Answered
PermalinkHistory
This may sound strange, but I believe if the SIM isn't seated properly this can occur also. I think it's much more likely the antenna is damaged though, the flex cable is delicate.
0
Score
Avatar
bmalam
31
Answered
PermalinkHistory
Hate to state the obvious, but have you tried a reboot?
I think you can't comment until you have 30 reputation, but in the future this would be better as a comment instead of an answer.
Nat Welch,
0
Score
Avatar
cam
Answered
PermalinkHistory
My phone is having the same problem, i lose service all the time and its in the open where i always get service. i try to reboot and it doesnt work, reset the network settings and it doesn't work, turn it on airplane mode and it doesn't work. and then sometimes it doesn't lose service for hours. what do i do?
0
Score
Avatar
nanfang
Answered
PermalinkHistory
I have exactly the same problem with CAM. i ever dropped my iPhone :- and then the problem happened.
0
Score
Avatar
Zeb
Answered
PermalinkHistory
I have the seame problem of "No Service"...... It has been sent to a repair center and they have said that the charger socket is damaged and so the repair is not covered by warranty...... There is no problem with charging or conecting to iTunes, is it possible for a damaged charging socket to cause "No Service"??
Dock or "charging socket" has the antenna on the underside of this plastic piece. It is cheap and easy to replace the entire dock connector which includes mic/speaker/charging socket and the antenna. Follow repair guide for dock in upper right of this page. Please start your own question too!!!
pollytintop,
0
Score
Avatar
dynastyaw
Answered
PermalinkHistory
If i was u just replace the antenna or put a foil on it that covers the battery and the signal well give it a big boost and it shouldnt be cut off anymore. That's what did and it's works good :)
Edited by: dynastyaw ( )
0
Score
Avatar
rudy
Answered
PermalinkHistory
my iphone 3g 16g just have an apple logo when i started up.. just that.. why???
what must i fixed??
Add Your Answer
