What are the dimensions and weight of the iPhone 4 battery?
I'm curious about what portion of the iPhone 4 volume and weight is attributed to its battery. Could you post the dimensions and weight of the battery?
There's a clear picture of the battery dimensions as in relation to the iPhone's.
The battery is-
Li-ion Polymer Battery
3.7V 5.25 Whr
APN: 616-0513
VPN: LIS1445APPC
The iPhone is-
Height:
4.5 inches (115.2 mm)
Width:
2.31 inches (58.6 mm)
Depth:
0.37 inch (9.3 mm)
Weight:
4.8 ounces (137 grams)
here's the certificate
Annnnddd some clear shots of the battery. Hope it helps! It's all I can do short of getting my hands on one and busting out a postage scale and tape measure.
cheers!
-tabormeister
Does anyone have accurate dimensions and weight for the battery?
I would like to know this also. What are the physical dimensions of the battery? Has anyone measured the battery with calipers?
Thank you.
if you check for the battery in any re-seller web you will find full specs.
4S battery weight 26g
Actually, it was the teardown that got me wondering. They mention that the battery takes up much of the phone's volume, but not how much. The battery's electrical specs are given, but not its weight or dimensions. Maybe I'm overlooking something, but I'm pretty sure it's not there. I also tried Google, but no luck.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 14,985
