0
Score
Avatar
Michiel
11
Asked
Hardware battery indicator button is lame
History
Hi guys,
Great work you are doing with the website! Always great fun to watch the new teardowns :)
Question: I don´t see any spare parts for the hardware piece of the battery indicator, with those green leds? Can you provide one, or tell me where to find it?
Thanks!
Michiel
Edited by: Michiel ( )
I found out why my battery led indicators were malfunctioning. The button on the outside to activate the led indicators comes back out after pushing because of a circular piece of black foam. In my MacBook, this foam was worn out. I replaced it with pieces of new foam that I cut from an adhesive band with foam (that one uses to diminish draft through windows). Quite a hassle, but the indicators work fine again. If you need directions let me know.
Michiel,
Post Answer
0
Score
Avatar
Chris Brazier
31
Answered
Accepted Answer
PermalinkHistory
+1 for a replacement guide
Score
Avatar
The Landwhale
79
Answered
PermalinkHistory
Check bay, that's where I had to buy mine. It was around $30 shipped. Just make sure it's for your model, as mine is for the 2008 15" mbp. Couldn't find it on here or anywhere but eBay.
Score
Avatar
nick
15.7k
Answered
PermalinkHistory
Try restting the SMC support.apple.com/kb/ht3964
You may want to reset the PRAM holding command, option, p, r together, shutting the computer down
That will possibly do something, it may or may not
nick,
Score
Avatar
adlerpe
301
Answered
PermalinkHistory
Hi Micheil...
If you have directions, I'd sure appreciate getting them. I'm having the same problem on my own Aluminum Macbook, and I'd like to try the repadding technique before going to the trouble of replacing the LED/button module.
Ideally, if you could take photos of the process and post it as a Step-by-step guide, then everyone gets the benefit of your ingenuity!
hi adlerpe, you probalby found a solution already, sorry for not responding.. The foam is attached to the upper case (with the keys on it). Replacing it with a new one is not possible, unless you switch the entire upper case (pretty expensive!). Try to pry out the old foam, cut a new piece with some scissors (including the hole in the middle). It should work. I did not find any trouble with the battery itself, so it is just the indicator leds that are confused. If you dont mind that, better leave it that way and save yourself the work!
Michiel,
0
Score
Avatar
lcrol
Answered
PermalinkHistory
Hello from Spain. I have a macbook pro 15 unibody 2.4 Late 2008. My battery indicators leds don`t work fine. Sometimes do not turn on and make strange things. I reset smc , pram put out battery... nathing fixed it.
Please can somebody send me a link for this part and how change it?? It is a single part or makes part of the motherboard??
Thanks a lot.
Add Your Answer
