The Nokia Lumia 900 is a Windows Phone 7.5-powered smartphone with 4G LTE support and a ClearBlack AMOLED capacitive touchscreen.
11 Questions View all
My phone isn't charging
My phone isn't charging and when I checked to see if anything was wrong, I noticed that the usb port to my phone has been literally pushed into the phone and also I believe it is damaged, how do I replace the usb port dock connector ?
Add a comment
take it to a phone repair store or do the repair your self
Add a comment
You can purchase a new motherboard and install it or try doing some micro soldering and replace just micro USB port. I would go with placing the motherboard but, its up to you. I wish good luck with your fix!!! :)
Add a comment
Quick and free of costs:
This problem is caused by the build up of dust in the USB socket. Consequently the plug can no longer be inserted properly.
In order to avoid short circuiting during the procedure remove the battery. Take a needle and pick out all dust and dirt form the USB socket. Keep going, you'll be amazed by how much will come out.
Once cleaning is done you can reinstall the battery.
Plug will go in like never before ;-)
Add a comment
Add your answer
saradadabiedeen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 244
