Score
Avatar
Tibus
23
Asked
Thunderfly stuck in the middle of the screen ...
History
Hello,
Everything is said in the title, I have a thunderfly dead in the middle of my imac :(
Any tips ? Found some on Google but nothing really helpful ..
Thanks !
Update
FYI, it finally collapsed yesterday at the bottom of the screen ! :)
In the meantime, I had others flies crawling around and I just shutted down the iMac as soon as one go under the glass.
Regards,
Laurent
Edited by: Andrew Bookholt ( ) , Tibus ( )
Post Answer
Score
Avatar
Taylor Arnicar
7.9k
Answered
Accepted Answer
PermalinkHistory
I find it very funny that this is apparently a not-uncommon problem: http://forums.macnn.com/58/imac-emac-and...
However, here's what you need to do:
Use this guide to remove the glass panel on your screen.
Use some canned air to blow the little guy away, or if he's melted into place, you may need to very gently clean the LCD with a soft cloth.
That should take care of things for you. :)
Hello Taylor and thank you a lot for this quick reply ! It's indeed fairly common as I already had the same issue with a Dell and a Sony monitor ... :-S I used to live with it for those monitors but it's quite annoying for a shiny new iMac :) I will check your solution but, if I see corretly, the bug is quite deep and below the cursor/pixels. Laurent
Tibus,
Glad to help, be sure come back and tell us if it worked or not, and if it did, accept this answer. :) -Taylor
Taylor Arnicar,
Add Your Answer
