My tablet won't charge. What can I do?
Whenever I try to charge my tablet it will not charge. What could be causing this and how can I fix it?
you have replaced the charging cable, right?
Same problem - the tablet crashed and won't boot, then I noticed the charging light blinked erratically and finally refuses to light up. I have tried several known good (tested on my smartphone) cables and wall chargers, and none of them will charge the tablet.
The battery might be dead. Also, make sure the device is plugged in properly when charging. It is also important to make sure the charger cable is not damaged.
Any suggestions for where to buy a replacement battery?
Also - would a bad battery keep the tablet from turning on if it's plugged in and charging?
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 11
All Time: 981
