The 2004-2008 F-150 truck was introduced in January 2003 for the 2004 model year as the redesigned eleventh generation of the F-150 lineup.
56 Questions View all
will power steering pressure switch cause hard steering at low rpm's
just replaced lower steering shaft & still hard to turn at low rpm's. steer's fine & easy after 10 mph.,so pump is working,could pressure switch failed or could resivoir filter be clogged?? how can i check these problems?
1 Comment:
How many miles on the truck and have you tried a flush of the pump and steering fluid
by
Add a comment
1 Answer
yes , it will . look for a collapsed hose or dirt in reservoir... if you can hear it whi ning when you turn the wheel its your power steering pump
Add a comment
Add your answer
john will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 24
All Time: 1,694
